May 18th, 2024, 2:58pm
Passive circuit voltage gain (Read 167 times)
raja.cedt
Sep 03rd, 2014, 3:39am
Dear all,
While reading Fast analytical techniques for
electrical and electronic circuits
book I found the attached passive circuit with voltage transfer function >1(1.12). I still didn't get the point,  how can passive circuit gives voltage gain. Can any one explain me the reason.
Raj.
aaron_do
Re: Passive circuit voltage gain
Reply #1 - Sep 3rd, 2014, 4:33am
A passive circuit can get voltage gain by a change in impedance. Conservation of energy is what's important. A transformer or LC network would do the job.
Aaron
Reply #2 - Sep 3rd, 2014, 2:58pm
the circuit drawn has a DC supply, so for that the C's fall out of the operating point.
Many circuits without amplifiers can give gain (reactive elements, switched capacitors, etc)
purely DC? that means the LC elements are all invisible, so I don't see that.
raja.cedt
Reply #3 - Sep 3rd, 2014, 3:38pm
@Aaron: Yes I know, we have to consider to energy conservation rather voltage gain. Till now I haven't come across any RC circuit with voltage gain>1
@loose-electron: no it's about some intermediate frequency. Can you give me one RC example. The reason why I am asking about this is, many LC networks provide gain >1 but these gain could be V/I or I/V but I haven't seen any Rc,LC ckt with V/V or I/I>1...
Raj!
RobG
Bozeman, MT
Reply #4 - Sep 3rd, 2014, 3:53pm
I can't remember how it actually works, but if the capacitance is voltage dependent it can be used to create gain. See http://ieeexplore.ieee.org/xpl/login.jsp?tp=&arnumber=1234357&url=http%3A%2F%2Fi...
aaron_do
Reply #5 - Sep 3rd, 2014, 5:03pm
If you include active elements like diodes or switches then there are other ways to get voltage gain. For purely passive switches, I don' know of any circuit which can give voltage gain at DC.
A transformer obviously can give voltage gain. I think you may have some confusion about LC networks (just read about the L-match) because they can also readily be designed with voltage gain (not just V/I or I/V). For RC, the amount of voltage gain which can practically be achieved might be very limited since they are inherently lossy (unlike LC networks) which is probably why you don't see them. I've never tried this circuit before, I'm just assuming the author wasn't lying.
Aaron
P.S. I just came across this article online called, "AC Voltage gain using just resistors and capacitors?" by Kendall Castor-Perry. You might want to google it...
raja.cedt
Reply #6 - Sep 4th, 2014, 2:24am
Dear Aron,
I still some how not convinced how it can give >1 gain (intuitively), any how I have to sit and  think properly. But thanks for the excellent doc.
Raj!
Lex
Eindhoven, Holland
Reply #7 - Sep 4th, 2014, 2:53am
I guess the text is about the zeros in the transfer function.  ;)
A Kumar R
India
Reply #8 - Sep 17th, 2014, 2:17am
Raja,
A quick analysis of the transfer function revealed it has a pole and a zero. For C1=C2 & R1=R2 case....zero occurs in front of the pole, which means, magnitude rises (>1) with frequency for sometime.
Bye.
