Apr 27th, 2024, 11:07pm
special file names in Verilog-A (Read 511 times)
sutapanaki
Sep 26th, 2014, 9:26pm
I want to run Monte-Carlo simulations, say 100 iterations and I want to record some data into a file with a name specific for each MC iteration. How can I do this in verilogA? Is there a way to append to the file name for example the time the simulation completes, or some other identifier specific to the MC iteration?
Re: special file names in Verilog-A
Reply #1 - Nov 13th, 2014, 10:30am
I don't recall that this is supported directly by the language; you should check with customer support for your simulator to see if they have special % codes for the analysis that you can use in Verilog-A, or if you can use them in a netlist to specify the output file as a parameter to your Verilog-A model.
