Apr 29th, 2024, 11:33am
A stimulus for digital signal using verilog-A (Read 1243 times)
Oct 04th, 2014, 6:45am
Hi Guys,
Is it possible to write a stimulus for digital signal using verilog-A? For example, a short verilog code is shown below.
/clock generator
  initial begin
	sclk_int = 1'b0;
	forever begin
	    #(40/2) sclk_int = ~sclk_int;
  initial begin
	 sdata = 1'b0;
	 #2000
	 sdata_master = 1'b1;
	 sclk  = 1'b0;
	 #500
	 repeat (1) @(sclk_int);
Thanks a lot.
Yawei
patrick
Santa Rosa, CA.
Re: A stimulus for digital signal using verilog-A
Reply #1 - Oct 5th, 2014, 1:01pm
Perhaps something like:
`include "disciplines.vams"
module clkgen(p);
output p;
electrical p;
reg sclk_int;
initial begin
   sclk_int = 1'b0;
   forever begin
analog begin
   V(p) <+ transition(sclk_int,0,1n,1n);
Reply #2 - Oct 5th, 2014, 9:33pm
Hi Patrick,
Reg is not allowed in verilog-A.
Quote:
Warning from spectre during AHDL compile.
   WARNING (VACOMP-1086):
       "/project/..../clkgen/veriloga/veriloga.va",
       line 10: `reg' is not a reserved keyword now but will be one in a
       future release. Parsing `reg' as an identifier for now.
Error found by spectre during AHDL compile.
   ERROR (VACOMP-2259): "reg sclk_int;<<--? "
       line 10: syntax error.
   ERROR (VACOMP-1592): "#(40<<--? /2) sclk_int = ~sclk_int;"
       line 15: invalid #line directive.
   ERROR (VACOMP-1814): Maximum allowable errors exceeded. Exiting AHDL
       compilation....
Yawei
patrick
Santa Rosa, CA.
Reply #3 - Oct 5th, 2014, 9:38pm
ok, I assumed you wanted to write a mixed domain model.
You will need to stick to the VA analog block and analog initial block; initial block and digital syntax is not allowed in Verilog-A.
boe
Reply #4 - Oct 6th, 2014, 1:17am
Ywguo,
this can be done using the timer function. For examples see the Oscillator models in the Verilog-AMS section of this web site.
- B O E
Reply #5 - Oct 6th, 2014, 9:33pm
Hi B O E,
That's a good idea. Thank you very much.
Yawei
