May 1st, 2024, 6:14am
Multiple Supply in a chip (Read 680 times)
Aj1234
Oct 08th, 2014, 10:40am
I had a question in Verilog AMS setup. Do you know how to use connect modules in a chip which have multiple supply domains. I know one method in which we write using ie card in amsd block in ams control file:
amsd {
… ie vsup=1.8
    ie vsup=3.3 cell=dig_buf
Does anyone know how to do this in cadence gui? Is there any tutorial?
AJ
boe
Re: Multiple Supply in a chip
Reply #1 - Oct 13th, 2014, 3:44am
Aj1234,
in ADE you use Setup->Connect Rules.
For tutorials, a quick search in Sourcelink should give you several hits, e.g. "Virtuoso AMS Designer Environment Tutorials" and "Running the Virtuoso AMS Designer Simulator from the Analog Design Environment and the Hierarchy Editor".
- B O E
