" S11=0 when input is complex matched" . It's wrong.
You should distinguish between "complex match" and "transmission line match". They are NOT identical.
I'd like to show you an example:
Zs=25 Ohm, Zload=100 ohm, connected with a lamda/4 length lossless transmission line (Z0=50);
Obviously, Gamma_s or Gamma_L is not equal to 0;
but they are conjugate matching in any position of the transmission line.
dog1 wrote on Oct 20th, 2014, 6:58am:I have a confusion about input matching. I know that S11=0 when input is complex matched. On the other hand, the equation for S11 is S11=(Zin-Z0)/(Zin+Z0), it is 0 when Z0=Zin, not its complex conjugate. Why is that?
Thanks!
