Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Sep 17
th
, 2024, 7:43pm
Home
Help
Search
Login
Register
PM to admin
Simulators
Circuit Simulators
› Create Symbol from Model
Previous topic
Next topic
Create Symbol from Model (Read 3848 times)
bki
Oct 29
th
, 2014, 8:54am
i have a external component that i want to simulate in Cadence.
It has 48 Pins. I have a spice model for it.
How can i create a symbol from the model in Cadence? I donīt want to draw a box with 48 pins by hand.
IP Logged
Frank Wiedmann
Munich, Germany
Re: Create Symbol from Model
Reply #1 -
Oct 30
th
, 2014, 2:33am
You could use the scasubckt component from the analogLib library. The description given at
http://www.designers-guide.org/Forum/YaBB.pl?num=1191334088
applies to IC5. In IC6, you don't need to add the dummy port to the netlist because the ref pin is simply ignored. See also
http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNu...
Another alternative would be to use the "Spice In" feature in IC6 (virtuoso -> File -> Import -> Spice) as mentioned in
. A detailed example for this is shown at
. From the created schematic, you can automatically generate a symbol view with Create -> Cellview -> From Cellview.
IP Logged
bki
Reply #2 -
Oct 31
st
, 2014, 2:50am
I am student. I can not access those links.
Can you please explain how to do it?!
Thanks!
IP Logged
bki
Reply #3 -
Oct 31
st
, 2014, 3:21am
I have a txt file like ABC.txt as spice model file.
Within the file i have a statement: library ABClib
Then i try: File->Import->SPICE
Input: Reference library: ABClib
Output: library: mylibrary
I get an error due to the reference library.
What is the problem?
IP Logged
Frank Wiedmann
Munich, Germany
Reply #4 -
Oct 31
st
, 2014, 6:35am
Probably that the library ABClib does not exist in your environment.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
»» Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
