Hello All,
I am designing Series Parallel Charge Pump that is used in Power Management circuit to charge the battery.
Details:
It has variable input < 1V
Output voltage must be > 2V
[no load current limitation defined yet, max 500uA]
Can anybody explain me how to size capacitors and switches for the same? I am using multiple conversion ratio topology so using Series-Parallel capacitor.
Kindly help me understand.
