Aug 29th, 2024, 9:19pm
Sizing of capacitor, switches - Low Power Integrated Series Parallel Charge Pump (Read 1421 times)
ICD_life
Nov 12th, 2014, 1:33am
Hello All,
I am designing Series Parallel Charge Pump that is used in Power Management circuit to charge the battery.
Details:
It has variable input  < 1V
Output voltage must be > 2V
[no load current limitation defined yet, max 500uA]
Can anybody explain me how to size capacitors and switches for the same? I am using multiple conversion ratio topology so using Series-Parallel capacitor.
Kindly help me understand.
Sad Embarrassed
