Thanks petitidiot for your concern
![Smiley Smiley](https://designers-guide.org/forum/Templates/Forum/default/smiley.gif)
Yes, that's what I subsequently figured out!
On
simulating the open-loop gain with a load resistance of 10 M Ohm connected at the output, I found that the open loop-gain decreased, and the [ (open-loop gain of opamp) * (beta) ] approx. matched the loop gain found using STB analysis (CMDM = -1).
BUT,
correlating the Phase-margin between the two methods seems to be difficult. Like, the phase margin calculated from STB analysis (for closed loop with beta=1/11) should be better (i.e., more) than the P.M. from the open-loop gain Bode plot (as it is like the plot of A*beta with beta = 1)? - but, I am seeing the opposite!
...maybe the pole due to large 1 MOhm is affecting the P.M. when the f/b is used?...any idea on this?
