Sep 17th, 2024, 3:42pm
onchip 1:5 balun (Read 4325 times)
vlsi_design
onchip 1:5 balun
Jan 14th, 2015, 7:30pm
I want to design an onchip 1:5 balun. Can anyone suggest me books or IEEE papers?
Re: onchip 1:5 balun
Reply #1 - Jan 19th, 2015, 12:59pm
IEEE MTT research time. There are a bunch out there go search that journal.
Might be stuff in IEEE JSSC also but I would wager that MTT will have more.
totowo
SH, PRC
Reply #2 - Jan 21st, 2015, 6:52pm
You can use 3:4 turn ratio, with 3 parallel and 4 series.
Too large turn ratio will decrease the coupling coefficient k.
In my opinion, the best on-chip transformer paper is
<Monolithic Transformers for Silicon RF IC Design> by J. R. Long, Vol 35, No. 9, JSSC 2000
vlsi_design wrote on Jan 14th, 2015, 7:30pm:
View Profile totowo totowo   IP Logged
vlsi_design
Reply #3 - Feb 8th, 2015, 11:58pm
Hi loose-electron & totowa,
Thank you for your suggestions.
I have designed the balun in Cadence virtuoso layout. I want to export it to HFSS for EM simulation by exporting the .gds file. Can anyone provide me step by step tutorial for EM simulation in HFSS?
nazgul
Reply #4 - Mar 2nd, 2015, 4:20am
Designing a 1:5 balun with a good coupling coupling coefficient is very tough. Ultimately, it boils down to the trade-off between circuit area and coupling coefficient k.
Care to provide the details of the inductance of the windings that you are willing to target, that might help me in pointing you in the right direction??
For good understanding of on-chip balun, you can read the following links
http://marco.stanford.edu/swong/Haitao.pdf
http://smirc.stanford.edu/papers/IEDM98s-mohan.pdf
« Last Edit: Mar 2nd, 2015, 8:15am by Ken Kundert »
