Jul 25th, 2024, 9:16am
question about ADC spectral analysis (Read 6638 times)
sun
Jan 16th, 2015, 9:17pm
Hi
A matlab code for ADC spectral analysis is following:
clear;
afs = 1;   % 1V full scale
fs = 1e6;    %  1MHz sample rate
N = 2^11;   % number of samples
cyc = 67;
fx = fs*cyc/N;
t = linspace(0,(N-1)/fs,N);
B = 10;                        % internal ADC resolution
delta = afs/2^B;
y = cos(2*pi*fx/fs*[0:N-1]);
%quantize samples to delta=1LSB
y=round(y/delta)*delta;
s = abs(fft(y)/N/afs*2);
sdb = 20*log10(s);
sdb = sdb(1:N/2);  % drop redundant half
s = s(1:N/2);  % drop redundant half
f = (0:length(sdb)-1) / N;  % frequency vector (normalized to fs)
bx = N*fx/fs+1;
As = 10*log10(s(bx)^2);
%set signal bin to 0
s(bx) = 0;
An = 20*log10(sum(s));
SNR = As - An;
figure(1);
plot(f,sdb);
grid on;
text_handle = text(0.3,-30, sprintf('SNR = %4.1fdB\n',SNR));
fft output data contain a lot of 0s, resulting -infs in the dB scaled spectrum. The SNR calculated from the quantized signal is 43.1dB, which is far from the expected 62dB.
I don't understand above situations. is there any problem of quantization or fft?
« Last Edit: Jan 16th, 2015, 10:23pm by sun »
sun
Re: question about ADC spectral analysis
Reply #1 - Jan 18th, 2015, 1:15am
there is a bug in the code.
noise power should be calculated by:
An = 10*log10(sum(s.^2));
resulting SNR fit expected well. But I still dont understand why there are 0s in the fft results.
          Sun
eternity
Reply #2 - Jan 20th, 2015, 6:16am
Is there any definite trend that you see in the appearance of zeros in the output array which is used to plot the spectrum
Also its more readable if you plot a spectrum of 'continuous type' instead of dots.
Eternity
RobG
Bozeman, MT
Reply #3 - Jan 20th, 2015, 3:37pm
I forgot why the zeros are there, but they are so it is not a bug in your program. I just add a small amount (like 1e-6) to the spectrum before converting it to dB. I don't think the zeroes are there in a real system that includes thermal noise.
Reply #4 - Jan 23rd, 2015, 12:56am
Hello Sun,
Would you please plot with all dots connected one by one? Now those two plots are not discernible. I cannot find where is the signal in the first plot. What is the magnitude and frequency of the signal?
Yawei
sun
Reply #5 - Jan 24th, 2015, 9:14pm
Hi Ethernity
I can not see any obvious trend. Actually, there are -infs between consecutive two zeros.
Sun
eternity wrote on Jan 20th, 2015, 6:16am:
Eternity
sun
Reply #6 - Jan 24th, 2015, 9:22pm
Hi
I got a perty spectrum after I add some noise before quantizing. In a real adc. device noise will dither signal. As you said, someone told me that there are zeros in the fft output. I'm also want to know how to explain this.
Sun
RobG wrote on Jan 20th, 2015, 3:37pm:
sun
Reply #7 - Jan 24th, 2015, 9:28pm
Hi Yawei
There are -infs between zeros. I have no ideal how to plot data for all dots. The signal is 0dB at about 16.3kHz.
Sun
ywguo wrote on Jan 23rd, 2015, 12:56am:
Hello Sun,
Yawei
