Jul 16th, 2024, 11:18am
CML divider self oscilation frequency (Read 1689 times)
raja.cedt
Jan 20th, 2015, 2:33am
Dear all,
Can  any one  explain how a cml divider will have self oscillation frequency, since it is a two stage circuit each stage should contribute 90 deg at oscillation frequency. But each stage can provide 90 deg phase shift at very high frequency where almost gain drops to very low(I am assuming tail node is not contributing any phase). I think I missing some thing about the cross-coupled pair, I am modelling them as -ve resistance only.
Can any one explain where i am missing/point me to useful doc
Thanks in advance,
Raj.
Re: CML divider self oscilation frequency
Reply #1 - Feb 6th, 2015, 10:58am
Suggestion here- please post a set of block diagrams and schematics of what you have. The question as it is right now requires too much guessing on what is going on.
jerry
raja.cedt
Reply #2 - Feb 6th, 2015, 3:38pm
Sorry..
Question is how can two stage cml circuit oscillates here?
Reply #3 - Feb 9th, 2015, 10:41pm
the device is a cascade of
amplifier - latch - amplifier - latch - back to input
As the device operates in a linear manner, what is the gain and phase relationship of each stage  ? At te functional level that will tell you about the oscillatory behavior of the device.
Jeffrey987
Reply #4 - Mar 14th, 2015, 2:33pm
the latch has a resistance of -2/gm (like in a LC oscillator). Write down the impedance of the load (Cl//Rl//(-2/gm) and you will see when barkhausen is satisfied (Aloop = gm Load gm Load)
raja.cedt
Reply #5 - Mar 16th, 2015, 2:50am
Hi jeffrey987,
Thanks for your reply, in-case of RLC it is clear but here only R//(cl//-2/gm), which boils down to Cl//-ve res hence this contribute only +ve phase shift and again this will be 90 only at high frequency by that frequency gain of diff pair will very low.
Correct me if I am wrong.
Raj.
