AS,
No, I was referring to the initial conditions option in the oscillator analysis section. It was intended to speed up convergence for high Q oscillators, for example, crystal oscillators. Have you considered using harmonic balance analysis. Tested both analyses for a ring oscillator and the results matched. Used a a lot of tones for HB analysis, ~100 tones, that may be more than you will need.
