May 3rd, 2024, 10:14pm
Charge Pump Noise Simulation (Read 4686 times)
Mehdi Abderezai
Feb 23rd, 2015, 5:40pm
I have a question about the noise extraction of a charge pump + PFD. The published tutorial states to extract the current noise of CP when applied an offset phase to the PFD, and then convert noise current back into time Jitter by multiplying by Period/Kdet
For example, the noise is 10nA, the Period is 10ns, And the Charge Pump Delivers 50uA when turned on. That makes jitter = (10ns * 10nA)/50uA = 2ps?
And if so, this implies that if I double the period, the jitter will double, which does not make sense to me.
Thanks.
Online
Re: Charge Pump Noise Simulation
Reply #1 - Feb 24th, 2015, 11:25am
What you are computing is an input referred noise. By doubling the period you are also halving the gain of the PFD.
Mehdi Abderezai
Reply #2 - Feb 24th, 2015, 11:35am
Thanks for your reply Ken, yes I see that the gain of the PFD is halved when the period doubles, but then closed loop sim (verilog A simulation) would account for that and increase the observed jitter.
If do both, I increase the input referred PFD jitter and put it in the closed loop simulation, I feel like I would be double counting the jitter of the PFD.
-Mehdi
Online
Reply #3 - Feb 25th, 2015, 3:56pm
The point is that jitter is easier to model than noise. The signal at the input of the PFD/CP is time whereas at the output it is current. In your loop simulations you need to choose where you are going to inject the noise for the PFD/CP. It is easier to model and simulate if you inject it at the input in the form of jitter than if you inject it at the output as a noise current.
