May 6th, 2024, 11:43am
Two stage ring oscillator (Read 127 times)
raja.cedt
Feb 28th, 2015, 10:50am
Dear all,
Can any one explain how can a two stage oscillator works, basically I didn't understand how it is satisfying Barkhausen criterion. Attached is a sample ckt diagram with each stage being designed by diff pair with cross coupled pmos load?
I can only think of ideal integrator as delay cell so as to satisfy barkhausen criterion with two stages
if I replace cross coupled load with resistive load, will it oscillate?
Raj.
newic
Re: Two stage ring oscillator
Reply #1 - Mar 4th, 2015, 5:05am
hi
each stage provides 90 degree. The total shift will be > 180o with the help of negative R by the cross-coupled.
newic
Reply #2 - Mar 4th, 2015, 5:06am
it will not oscillate if you replace with R load. It can also oscillate  with inductive load.
raja.cedt
Reply #3 - Mar 4th, 2015, 9:06am
Thanks for the reply, could you please explain how -ve resistance help to get phase 90deg from each stage. From simple small signal model, this stage boils down to a diff pair with -ve resistance, means -ve phase shift but still can each stage contribute 90deg?
For me looks like diff between resistive load and cross coupled pair is sign only(from small signal)---is this correct?
Raj.
newic
Reply #4 - Mar 4th, 2015, 11:23pm
raja.cedt
Reply #5 - Mar 5th, 2015, 5:39am
Hi newic,
Good paper, but he is also using active inductor and making sure each stage contribute 90deg. In-fact with an inductive load single stage also suffices (ex--lc vco). But in the current scenario can we approximate cross coupled load with inductor, from small signal model I have got -ve inductor (similar to Gyrator except a polarity diff).
Any comments, sorry for asking many times, some how I am confused here..
many Thanks,
Raj..
