After several trials with the example, I am still puzzled about the resistor in the module. I have tested input value to resistor. It is found that it only accepts logic '1' or '0'. The current does change when there is one '1' at one of the two pins, but wire b logic does not show impact on the current.
In the following code,
Code:module testbench ();
electrical gnd;
ground gnd;
reg clk;
initial clk=0;
wire b;
wire out1;
always begin
#100
clk=1;
#100
clk=0;
#10
clk=1'bx;
#100
clk=0;
#10
clk=1'bz;
buffer buf0 (b, clk);
resistor #(.r(10)) r0 (b, 1);
The current image is as below:
http://i58.tinypic.com/2jdjgvt.pngI cannot figure out how the vertical axis values come out. Its maxim is Ampere?
When a number, such as '19' instead of '1' or '0' input, there is the following error message:
ERROR: instantiation of SPICE primitive 'resistor' failed (instance and model do not match: cannot connect a non-signal to the SPICE port 'SPICE Port', except "1'b1", "1'b0", "1" and "0"; actual expression has to be either a concatenation, or a part select or an bit select made of signals)
Although wire b has logic '1' and '0', it does not change the resistor current in the image.
Could you explain it to me?
