weber8722
isnt there a parameter to enter the clk amplitude? Use Edit Property, then swtich the cyclic field to "veriloga" to see all parameters. If this is still a problem use e.g. an vcvs from analogLib as little amplitfier. This is also needed for differential circuits.
Bye Stephan
