Dshoter
Hi. I have a verilog-A block in Spectre, and I want to perform a sweep in one of the variables of the block. Let's say that the variable name is X. When I choose the sweep option inside the analyses, I select "Component Parameter", and them give the name of my parameter.. I declared X as parameter.. But I'm getting the following error: "Real Value expected for parameter 'X'".
Any one knows how I can do this sweep?
Thank for your time.
With best regards.
