Joe Shmoe
Hi everybody,
I'm using verilog-A to describe a subcircuit which I implement in a HSPICE netlist.
The subcircuit comprises a set of functions that are interdependent. for example:
F1 = V(a,b)*C1 F2 = F1*C2*V(a,b) F4 = pow(F2,2)*exp(F1/C3) ... I(a,b) <+ F4 //voltage dependent current source
When I run HSPICE I would like to PRINT several functions of the subcircuit.
What would be the proper command in order to do so? (I'm running a transient analysis in HSPICE)
something like: .PRINT TRAN X1.....
Thanks for the input!
cheers, JS
