Apr 30th, 2024, 4:19am
Print Verilog-A subcircuit value using HSPICE (Read 4284 times)
Joe Shmoe
May 01st, 2015, 6:27pm
Hi everybody,
I'm using verilog-A to describe a subcircuit which I implement in a HSPICE netlist.
The subcircuit comprises a set of functions that are interdependent. for example:
F1 = V(a,b)*C1
F2 = F1*C2*V(a,b)
F4 = pow(F2,2)*exp(F1/C3)
I(a,b) <+ F4 //voltage dependent current source
When I run HSPICE I would like to PRINT several functions of the subcircuit.
What would be the proper command in order to do so?
(I'm running a transient analysis in HSPICE)
something like:
.PRINT TRAN X1.....
Thanks for the input!
cheers,
JS
Re: Print Verilog-A subcircuit value using HSPICE
Reply #1 - May 4th, 2015, 6:51am
Do you need it formatted as the output from .PRINT?
Otherwise, you could use $strobe within the Verilog-A module to print; I think that comes out in the standard output from the simulator.
Joe Shmoe
Reply #2 - May 4th, 2015, 8:32am
I would need in the format
.PRINT
any idea how to do that?
Thanks!
Reply #3 - May 4th, 2015, 11:21am
You probably need to set up the values you want to print as operating-poing variables.  Rather than
 real F1, F2, F4;
you declare them with
 (* desc="op-pt" *) real F1, F2, F4;
Then you should be able to print them the same way you would print GM for a transistor.
 .print dc x1:F1
Joe Shmoe
Reply #4 - May 5th, 2015, 11:34am
That worked out great!
Thanks Geoffrey!
