May 17th, 2024, 11:50pm
Psudo differential ring oscillator - bias voltage equation (Read 2076 times)
cmospll
India
May 25th, 2015, 10:26am
I am new to PLL design. I am trying to understand the exact relationship between the bias voltage, bias current of a current starved psudo-differential ring oscillator.
Attaching a screenshot for clarity.
Guidance/Help is highly appreciable.
- cmospll
View Profile cmospll   IP Logged
Re: Psudo differential ring oscillator - bias voltage equation
Reply #1 - May 27th, 2015, 8:19am
such methods work on paper but tend to be a noise and jitter problem in silicon.
if this is going to be a real piece of silicon I suggest you research other design alternatives
google: Maneatis ring oscillator
that will get you started
