Dec 13th, 2025, 8:38pm
Modelling of Vibratory Gyroscope using VHDL-AMS (Read 3930 times)
Harry_108
Jun 24th, 2015, 2:27am
I need little conceptual help on 2DOF vibratory gyroscope (please check the attached file).
I am modelling Mass spring damper system using VHDL-AMS.
in the design I have two mechanical resonator
I have done following connections.
terminal t1: translational;
there are 2 springs, 2 dampers and 2 masses in the system
suffix 1 is used for drive and 2 is used for sense resonator
spring_1:
P end is connected to traslational_ref;
n end is connected to t1;
Damper_1:
Mass_1: (has only one end)
p end is connected to t1;
now my question is how to connect  spring_2, Damper_2 and Mass_2 ???
appreciate your  earlier replies.
thanks,
Harry_108
« Last Edit: Jun 24th, 2015, 8:36am by Harry_108 »
