ValarMorghulis
I am trying do the noise margin analysis of a dynamic CMOS logic circuit (Domino) which is run by a clock signal. Now, what should be the procedure to do that? I am trying to follow something similar to standard method of measuring noise margin for an inverter using VTC curve.
Thank you for your time and co-operation!
