Apr 28th, 2024, 3:06am
VAMS clock period monitor- Help! (Read 4860 times)
Rosh
Jul 13th, 2015, 11:16pm
I would like to measure the ON time of a clock pulse.
`include "disciplines.vams"
module measure_periods(in);
parameter real vdd_half=2.5;
input in;
voltage in;
real t0, t1;
analog begin
@(cross(V(in)-vdd_half,1))   //record time when clock rises beyond Vdd/2
t0=$abstime;
@(cross(V(in)-vdd_half,-1))    //record time when clock falls beyond Vdd/2
t1=$abstime;
t1=t1-t0;
Will t1 record the ON time? Is this logic correct?
boe
Re: VAMS clock period monitor- Help!
Reply #1 - Jul 14th, 2015, 3:27am
Rosh,
t1=t1-t0;
will be executed every time step.
- B O E
Rosh
Reply #2 - Jul 14th, 2015, 3:29am
Hi BOE,
Thank you for the reply.
How will ensure that I print only one output instead of printing it continuously?
Thank you
boe
Reply #3 - Jul 14th, 2015, 8:17am
Hi Rosh,
I recommend you use Code:
t1=$abstime;
t2=t1-t0;
as block at the falling edge event.
- B O E
Rosh
Reply #4 - Jul 15th, 2015, 2:15am
Thank you BOE
