Jan 9th, 2026, 3:29pm
detect if a pulse train has an irregular pulse intervals (Read 2879 times)
jovial
Jul 18th, 2015, 11:53pm
i
I have a pulse train. I have to detect whether the pulses are coming at regular intervals or irregular intervals (just yes or no).
Can anyone suggest a simple analog circuit based solution for the same??
Re: detect if a pulse train has an irregular pulse intervals
Reply #1 - Jul 19th, 2015, 1:52pm
without knowing more details:
take pulse train and clock a divide by 2 circuit.
output of divide by 2 should be 50% duty cycle if pulses remain evenly spaced
low pass filter 50% duty cycle wave giving a voltage that is roughly Vpower/2
set up 2 comparators with trip points slightly above and below Vpower/2
digital signals low-middle-high result
when low or high asserts the pulses are not evenly spaced
That is, as requested, an analog method.
A digital method could use the pulses to start-stop counters and compare the difference.
Other solutions are possible as well (PLL and watch the phase detector output and probably others as well)
RobG
Bozeman, MT
Reply #2 - Jul 21st, 2015, 12:08am
I can't think of a better "simple analog" solution than loose-electron's, but doing that requires a lot of low pass filtering so it will be large and it will take many clock cycles to settle. I think you want his "digital" solution even if you have to make a simple oscillator to do the counting.
Reply #3 - Jul 21st, 2015, 1:20am
What about writing a behavioral model that measures the time between pulses and reports 1/0.
  0 if the delay is the same
  1 if the delay is different
need to include some margin for error to account for finite
numerical resolution.
If post simulation why not plot the frequency. It will be constant if the
interval is constant.
