Aug 14th, 2024, 8:17am
Generic port width (Read 241 times)
Sammekevremde
Generic port width
Sep 09th, 2015, 2:49am
Hi i'm using cadence virtuoso and i'm trying to use a generic to determine the port width in a vhdl entity.
entity Voter is
      generic ( width : integer := 8 );
   Port ( input1 : in  STD_LOGIC_VECTOR (width-1 downto 0);
          input2 : in  STD_LOGIC_VECTOR (width-1 downto 0);
          input3 : in  STD_LOGIC_VECTOR (width-1 downto 0);
          output : out  STD_LOGIC_VECTOR (width-1 downto 0));
end Voter;
when i compile this it gives me the warning.
*WARNING* (DB-270000): dbCreateNet: Input name(or member) : input<width-1:0> has improper bus syntax
*Error* dbCreateTerm: argument #1 should be a database object (type template="dgtxg") - nil
Error failed to create shadow database for (work voter entity).
i've tried to put brackets around the (width-1) which doens't work either.
boe
Re: Generic port width
Reply #1 - Sep 10th, 2015, 5:08am
Sammekevremde,
AFAIK Cadence Virtuoso (Schematic/Symbol editor) does not support this.
- B O E
Sammekevremde
Reply #2 - Sep 10th, 2015, 11:49am
Thank you Boe.
To bad it isn't supported, would be really nice to be able to use a component multiple times with different parameters.
