Dec 17th, 2025, 3:50pm
Relationship between phase jitter and K-cycle jitter. (Read 3273 times)
Homer
Sep 16th, 2015, 10:21am
I'm trying to simulate the phase jitter of a VCO within certain integration frequency range. And it seems there is no direct phase jitter result could be plot in pnoise simulation. But there is K-cycle period jitter. So if I increase K number untill the jitter number doesn't change anymore, can I think this K-cycle jitter is the phase jitter?
I need this number for a Serdes jitter budget. Normally I will use a spreadsheet to calculate the phase jitter of which the input is phase noise result of pnoise simulation.  But I do want get this number from spectre directly.
Thanks!
Frank Wiedmann
Munich, Germany
Re: Relationship between phase jitter and K-cycle jitter.
Reply #1 - Sep 17th, 2015, 2:37am
If you are simulating with noisetype=pmjitter, then Jee might be what you are looking for. Jc for large k values should be the same as Jee multiplied by sqrt(2) (because the duration of a period is influenced by two edges).
