Jul 20th, 2024, 9:26am
db2bisonbl parameters issue (Read 1153 times)
ic_engr
Sep 28th, 2015, 8:10am
We were designing a structure for diode in High Voltage Process. The NWELL was extended to the HVNWELL Boundaries. The structure when extracted gives a db2bisonbl with areantop and perinint of 0.
When these parameters are set to zero, the spectre simulation ends with this error: I0.dpepinblsub: Value of `is' should be greater than zero.
Any suggestion to solve this problem?
ic_engr
