Jul 20th, 2024, 7:30pm
PC Architecture Northbridge Chipset (AMD/Intel) Design (Read 785 times)
vicm6799
Oct 12th, 2015, 10:11am
Could anyone familiar with the design of the die belonging to any older model AMD or Intel Northbridge chipset ? This chipset (IC) is found on computer motherboards.
1. Does the NB chip have a processor core or simply a core (logic) ?
2. If the NB chip does have a core would it be just one single core (logic) or multiple cores (logic) ?
3. If the NB does have an embedded core (logic) on die is it loaded by a boot loader ?
4. If NB does have a boot loader where on the NB die would the boot loader be found ? Would it be found somewhere in the flash memory on the NB die ?
Re: PC Architecture Northbridge Chipset (AMD/Intel) Design
Reply #1 - Oct 21st, 2015, 5:19pm
how is this an analog design question?
vicm6799
Reply #2 - Oct 21st, 2015, 7:20pm
loose-electron wrote on Oct 21st, 2015, 5:19pm:
hello loose-electron.
thanks for the response. I do apologize for the incorrect group but I was not sure whether the IC falls under analog or digital signal circuits. I have just found out that the technology uses digital signals. I have posted a similar question on Mixed-Signal Design group. Maybe you could be kind enough to help us with our questions. Thanks
Reply #3 - Oct 23rd, 2015, 5:40pm
why don't ypu contact the manufacturer of the devices and ask them? Or go get the specification for the device?
