May 19th, 2024, 11:50am
5th order LC filter with inf. RL and near zero Rs (Read 2378 times)
neoflash
Mixed-Signal
Designer
Nov 29th, 2015, 7:52pm
Most filter design handbooks are about filters with finite RL and RS. I am just wondering whether there is a cheat sheet to design filters with capacitive load and low impedance driver.
Neo
nrk1
Re: 5th order LC filter with inf. RL and near zero Rs
Reply #1 - Dec 5th, 2015, 3:02am
With zero Rs and infinite RL, you will have a lossless(=undamped) network with poles/zeros on the imaginary axis. One of the resistances has to be non-zero. In that case, you can design singly terminated ladder filters. Singly terminated prototypes are also available, or you can solve the nonlinear equations for the component values in matlab or a symbolic solver.
neoflash
Mixed-Signal
Designer
Reply #2 - Dec 7th, 2015, 12:17pm
Thanks for pointing out this will make lossless network. I meant the source impedance should be quite low.
I tried to fine some singly terminated prototypes for LC ladders. Could you please suggest some good references?
nrk1 wrote on Dec 5th, 2015, 3:02am:
Reply #3 - Dec 7th, 2015, 12:21pm
http://www.amazon.com/Handbook-Filter-Synthesis-Anatol-Zverev/dp/0471749427
Zverev is the bible - pre dates computers and spice.
