Jul 21st, 2024, 7:25pm
FET intrinsic gain characterisation (Read 3062 times)
zulqar
Dec 05th, 2015, 1:40pm
Hi everyone,
I am characterizing a Field effect transistor with a verilog A model using spectre. I want to plot gmro (intrinsic gain) vs vds. But the problem is that, the model does not store gm or gds values in dc operating points. Is there any test bench from which I can extract gmro vs vds plot without actually getting gm and gds values individually?
Any suggestion is appreciated.
Thanks!!!
Re: FET intrinsic gain characterisation
Reply #1 - Jan 5th, 2016, 6:30am
If you have the verilog-a code, you could add those operating point values.
Reply #2 - Jan 5th, 2016, 10:34pm
Do you mean gmro? You can use two AC analyses, one to measure gm, the other to measure ro.
