Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Sep 28
th
, 2026, 9:49am
Home
Help
Search
Login
Register
PM to admin
Modeling
Semiconductor Devices
› HDL source code for NPN & PNP transostors
Previous topic
Next topic
HDL source code for NPN & PNP transostors (Read 4395 times)
loumbut5
Kenya
Dec 05
th
, 2015, 12:15pm
Hi, does anyone know where I can get verilog/vhdl source code for NPN and PNP transistors?
I am specifically looking for a design where the current can flow in both directions i.e. the collector and emitter can switch places if the flow of current requires it.
The best example of what I mean comes from the NPN, PNP models in Circuit Simulator v1.5n
Thanks for your help.
IP Logged
loumbut5
Kenya
Re: HDL source code for NPN & PNP transostors
Reply #1 -
Dec 6
th
, 2015, 3:57am
Hi, I managed to decompile the jar file Circuit Simulator v1.5n in order to get the source codes for the NPN, PNP transistors. I then converted the code to C++ which I then intend to convert to HDL to see if it will suit my purposes. Anyway I have attached the resulting C++ source code and am asking if the code when converted to HDL will have the characteristics I require. Any help is highly appreciated.
C_codes.zip
IP Logged
Reply #2 -
Jan 5
th
, 2016, 6:32am
There are Verilog-A descriptions of a few standard BJT models (Hicum, Mextram, VBIC) available on the web, and they are open source.
If you're looking for basic Gummel-Poon, I don't know if there's an open-source version available.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
»» Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2026
Designer’s Guide
All rights reserved.
Send comments or questions to
[email protected]
. Consider
submitting
a paper or model.
