Jul 21st, 2024, 7:22pm
MOSFET Spice models question (Read 3540 times)
Torq
Dec 23rd, 2015, 1:33am
Hi!
I model some digital circuit working with near/under threshold voltage supply, and i doubt about precision of transistor model. I am using  TSMC 65nm process, which uses BSIM4.5 Level 54 models. Is it enough for accurate model the under threshold behavior of MOSFET, or i need some better models?
Thanx!
Re: MOSFET Spice models question
Reply #1 - Jan 4th, 2016, 5:34am
I think BSIM4 can model subthreshold behavior, but the question is whether the foundry has extracted the model parameters accurately enough for that region.  You may also find that you are more susceptible to interconnect parasitics when you operate with a low supply voltage: if there's a lot of parasitic resistance, for example, then the IR drop may push the supply too low.
Torq
Reply #2 - Jan 4th, 2016, 12:12pm
Geoffrey_Coram wrote on Jan 4th, 2016, 5:34am:
Thank you, Geoffrey! I think, you're right, the parameters precision outside the working range is very questionable. From the other hand, the near threshold voltage (NTV) is not something unusual: NOR4 cell, for example, includes 4 pmos between supply and output, so some of that pmos is likely operates at NTV.
I'm not sure i clearly understand you. But, it seems not possible to design synchronous circuit for NTV supply because of all things you describe.
I'm planning to use asynchronous (delay-insensitive) digital design which is robust to PVT variations (and to the IR-drop in particular). So asynchronous logic must operate at NTV. The only question is how close the simulation to the real silicon life.
