Jul 1st, 2025, 7:07pm
1GSa/s ADC: decoupling for power domains isolated by deep n-wells? (Read 14989 times)
spectrallypure
Dec 5th, 2015, 8:31pm
Hi! I'm having a hard time trying to figure how to implement the on-chip decoupling of the various power domains in my chip. I am implementing a 1GSa/s pipeline ADC in a bulk CMOS process with deep N-well option. The chip floorplan is shown in Fig. 1, and the floorplan of each pipeline stage is shown in Fig. 2. As shown in these figures, I have the following 5 different power domains (please note that besides the logic used for clock signals generation and distribution, I have no other digital circuitry in my chip; all processing/calibration will be done off-chip):
-Vdd_A,Vss_A: the amplifiers power domain,
-Vdd_SW,Vss_SW: the bootstrapped switches power domain,
-Vdd_CMP,Vss_CMP: the comparators power domain,
-Vdd_D,Vss_D: the clock signals generation, buffering and distribution power domain, and
-Vdd_IO,Vss_IO: the output buffers power domain (***I'll make no further reference to this domain since it has already been decided that it will be kept completely isolated from the other 4).
Wherever it happens, each power domain is implemented and contained in a separate deep-N-well region, so in principle all the power domains are isolated to each other (looking back this might not have been the most clever decision, but the core of the ADC has already been laid out like this). Now I need to implement the onchip decoupling of all these power domains, and I'm considering the following 2 options:
OPTION "A": keep all the domains separate and independent.-
A simplified diagram of this option is shown in Fig. 3, and its corresponding decoupling scheme in Fig. 4. As can be seen from these figures, the Vdd and Vss of each domain are decoupled with respect to each other, but no connection/decoupling is implemented between the domains. I believe the pros and cons of this option are:
-Pros: domains completely independent --> maximum isolation
-Cons: domains don't share a common reference --> they could "bounce" relative to each other and induce errors!
OPTION "B": short the grounds of all the power domains.-
A diagram of this option is shown in Fig. 5, and its corresponding decoupling scheme in Fig. 6. Now the domains share a common ground and the Vdd of each domain is decoupled with respect to it.
-Pros: domains share a common reference --> they all would "bounce" together (is this actually a "pro"?)
-Cons: I am shorting the regions that I originally intended to be isolated! (i.e. "local p-sub" regions inf Fig. 5). Even worse, if I also connect the substrate to the common ground (which I most certainly would), then I would be in effect shorting the regions at each side of the deep-N-wells, defying their presence and purpose as "isolation walls" between these regions! (i.e. why would I have put these walls to begin with, if I was going to short electrically the regions they are separating?).
I would really appreciate if anybody could please share any thoughts on this problem. What do you think would be the best option to take? Or maybe non of the above described?
Thanks in advance for any help/advice/comments.
Cheers,
Jorge.
« Last Edit: Dec 06th, 2015, 12:28am by spectrallypure »
spectrallypure
Re: Onchip decoupling for power domains isolated by deep n-wells?
Reply #1 - Dec 5th, 2015, 8:32pm
Fig 1) Chip Floorplan and Fig. 2) Pipeline stage floorplan and power domains
spectrallypure
Reply #2 - Dec 5th, 2015, 8:34pm
OPTION "A": Fig. 3) Power domains connection and Fig. 4) Decoupling sheme
spectrallypure
Reply #3 - Dec 5th, 2015, 8:34pm
OPTION "B": Fig. 5) Power domains connection and Fig. 6) Decoupling sheme
wave
Re: 1GSa/s ADC: decoupling for power domains isolated by deep n-wells?
Reply #4 - Dec 6th, 2015, 11:37pm
spectrallypure wrote on Dec 5th, 2015, 8:31pm:
Jorge - I'm going to assume this is a research design.
Kudo's for paying attention in the noise/isolation lectures.  You got the theory right, and already seem to see the problem of too much area and complexity.  Not too mention the unrealistic real world of fewer supplies (external regulators, cost, etc.).
DNW isolation is not always even supported in some PDK's so check that first.  Is it too late for a blanket delete of DNW?
If you insist on all these DNW, think about combining some (all?) of the analog supplies (VDD and VSS), in beefy metals.  Maybe even analog and digital together?
Heck, split these ideas in your tapeout.  You'll get another paper comparing isolations strategies!   Cool
Wave
Reply #5 - Dec 28th, 2015, 4:18pm
Deep N Well Isolation is not the answer to the world's problems.
You get capacitive coupling through the PN junction of the DNW and the resistive nature of it allows the coupling to not be killed off by the low impedance bias connection.
RobG
Bozeman, MT
Reply #6 - Dec 30th, 2015, 2:37pm
loose-electron wrote on Dec 28th, 2015, 4:18pm:
I think it was you that told me the deep nwell doesn't buy you much since they are all capacitively coupled. Since then I've heard the same from other sources. That is, the substrate node is an AC short even with NWELL. I think someone told me floating the DNW helped a bit.
The real issue is when currents leave one power domain into another.
There is a paper written on this site about decoupling and bypassing.
Reply #7 - Dec 30th, 2015, 7:12pm
Yes that was me. When I was at IBM we had a long "discussion-argument" over the merits of Deep N Well isolation.
At the end of the day we fabbed some test circuits and did some testing.
Helps some, but not a lot to get excited about.
spectrallypure
Reply #8 - Dec 31st, 2015, 12:09pm
Thank you all for your replies! (sorry for the delay; the end-of-year rush kept me really busy!).
I have decided to go for Option "B", both for its greater simplicity (too late to delete the Deep-N well layer from all cell layouts --it's hardcoded to the pcell of every MOS device in the PDK), specially speaking about decoupling, and because it is somewhat closer to a more realistic scenario of just having 1 or 2 power domains (although this is a research project, I need to remain as realistic as possible).
After resorting to every source of advice I could think of (including, of course, you guys), the general feeling I got is that this topic is rather badly documented. I suspect that this might have to do with the fact of DNW isolation providing only marginal benefits. If somebody knows of any reference related to these topics (i.e. deep N-well isolation and/or onchip decoupling), I would be really grateful if you could point it out (maybe you, RobG?).
Thanks again for your help, and Happy New Year!!!  :)
Cheers,
Jorge.
RobG
Bozeman, MT
Reply #9 - Dec 31st, 2015, 1:34pm
Here's the paper written by the site owner Ken Kendurt: www.designers-guide.org/design/bypassing.pdf
It's a really complicated topic. Mostly you want to use decoupling to keep the noise currents from creating noise on another block. Be very aware of currents leaving a domain - especially off chip - they have to come back somewhere (Kirchoff's Law) and that will create the noise. Sketch out the circuit blocks and see how the bus drop from one block influences what the other block sees.
spectrallypure
Reply #10 - Jan 4th, 2016, 7:29am
Thanks so much for the link and the comments, RobG; very useful information! Cheesy
I'm getting the feeling that understanding and putting all these concepts together correctly for the case of a complex chip will take me more than a couple of tapeouts to figure out!
Any other tips/references are certainly welcome!
Cheers,
Jorge.
Reply #11 - Jan 10th, 2016, 7:44pm
spectrallypure
Reply #12 - Jan 13th, 2016, 2:37am
Wow! thank you so much for posting your article, Jerry! I'm going over it right away! Smiley
Cheers,
Jorge.
Reply #13 - Jan 16th, 2016, 10:02pm
spectrallypure wrote on Jan 13th, 2016, 2:37am:
Cheers,
Jorge.
No problem, if you got questions LMK, I got a laugh out f digging that out considering how long back I published that.
