May 2nd, 2024, 11:43am
AMS Errors in Sacle Factor (P=10e+15) (Read 777 times)
frozenduck
Dec 17th, 2015, 11:27pm
Dear all,
I am running AMS in IC615. If I simulate with Verilog blocks only, it works well.
After I include circuits including transistors, error occurs.
The errors shown in ncvlog.log are
ncvlog: *E,UXEXID (.../schematic/verilog.vams,20|58): Unexpected identifier 'P' after completed expression.
nch_ulvt_mac #(.ad(1.5E-14), .nrd(2.828877), .spmt(1.11111P), .spomb(0),
I guess it is because the tool cannot recognize the scaled notation "P" which is 10e+15.
However, this parameter is defined in PDK and I can not modify it.
Is there anyway to solve this or this is not the root cause?
Thank you very much.
Re: AMS Errors in Sacle Factor (P=10e+15)
Reply #1 - Dec 18th, 2015, 7:10pm
Only Verilog-AMS understands the SI scale factors. Make sure you have specified the -ams option to ncvlog.
If that is not the problem, perhaps your simulator does not support the very large or very small scale factors. Does it work with the more common scale factors like k, m, M, u, etc.
Reply #2 - Jan 5th, 2016, 6:33am
Verilog-AMS doesn't support P; as of LRM version 2.4, it only goes up to T.  (I assume you meant 1e+15, not 10e+15.)
frozenduck
Reply #3 - Jan 20th, 2016, 2:53pm
To Ken,
Yes, I used Verilog-AMS and other SI scale factors work well.
To Geoffrey,
Yes, I meant 1e+15.
Is there any solution or suggestion?
Since the PDK is a practical one and provided from the foundry, I think everyone will have the same issue.
Thanks.
