Apr 26th, 2024, 11:49am
Netlisting failed with multiple Verilog-A blocks (Read 4303 times)
yong_rfic
Jan 12th, 2016, 6:49am
I have encountered netlist errors when trying to simulate circuit which has two simple Verilog-A blocks. Each individual block can be nestlisted successfully. However when I put them in the same schematic, there are errors. The error messages are:
"ERROR (OSSHNL-524): Netlisting failed as function hnlNetNameOnTerm was called with a non-existent terminal name on current instance 'I1' in design 'RF14/cal_logic_decod/schematic'. Ensure that argument to this function is a valid terminal name and netlist again.\n\n"
and many more of the same thing...
The two verilog-a blocks are defined like
module A(B_in, T_out);
input [4:0] B_in ;
electrical [4:0] B_in ;
output [15:0] T_out ;
electrical [15:0] T_out ;
module B(clk, vin, vout);
input vin, clk;
output [4:0] vout;
electrical vin, clk;
electrical [4:0] vout;
Please advise, thank you.
Re: Netlisting failed with multiple Verilog-A blocks
Reply #1 - Jan 14th, 2016, 5:14am
I suspect there is something subtle in your set-up that's causing trouble, and it may be something related to the actual definitions of your blocks.  (I think your modules aren't actually "module A" and "module B")
I assume each block has a symbol view and a verilog-a view.
I would try replacing one of the blocks with a simple verilog-a module, maybe something as simple as a resistor or a voltage source.  Or try it with a voltage source and a resistor as your two verilog-a blocks, and make sure you can netlist a schematic with those two simple blocks.  Then work up from there.
yong_rfic
Reply #2 - Jan 14th, 2016, 7:14am
Thank you for the useful advice. I ended up combining the two modules into a single one. Problem solved at least for now.
andrew terry
Reply #3 - Jan 31st, 2018, 2:50pm
I had the same error. To fix I instantiate the second block fresh with create instance (i). Do not copy from the first instance.
