May 4th, 2024, 5:14pm
How to read a *.log file into VerilogA? (Read 4489 times)
Jacki
Jan 14th, 2016, 10:08am
   I am quite new to VerilogA. Currently I want to read a .log file into VerilogA and use the transition filter. The file is just a lot of "0" and "1", and either "0" or "1" in each line. How can I read it correctly? I try to use fscanf(), but I get the syntax error. Could anybody help me to correct the error?
// VerilogA for VerilogA, readfile, veriloga
`include "constants.vams"
`include "disciplines.vams"
module readfile (clk, out);
 input  clk;
 output out;
 electrical out, clk;
 integer pwmfileA;
 real hold;
 real pwm_A[0:1024];
 genvar i, k=0;
 parameter real thresh=0.6;
 parameter tr=1n, tf=1n, dy=0;
 integer j=1;
analog begin
 @(initial_step) begin
   pwmfileA = $fopen("./pwm_A.log","r");  // here report an error
   $fclose(pwmfileA);
   for (i=0; i<1024; i=i+1) begin
     pwm_A[i] = $fscanf(pwmfileA,"%d",j);  //here report an error
     j=j+1;
 for (k=0;k<1024;k=k+1) begin
   @cross(V(clk)-thresh, +1)
     hold = pwmfileA[k];
     V(out) <+ 1.2*transition(hold, dy, tr, tf);
the reported errors are shown here:
Error found by spectre during AHDL compile.
   ERROR (VACOMP-1149):
       "./veriloga.va",
       line 26: Genvar loop evaluation failed. Check whether `/usr/bin/perl'
       is available.
   ERROR (VACOMP-1816): Exiting AHDL compilation.
   Any comments are welcome.
   Thank you.
   Jacki
Jacki
Re: How to read a *.log file into VerilogA?
Reply #1 - Jan 15th, 2016, 12:17am
   In fact, my question can be simplified to be "how to read a text file into a vector"? The text file has 1024 lines, each line is a binary data either "0" or "1".
   Thank you.
   Jacki
Jacki
Reply #2 - Jan 15th, 2016, 3:51am
Problem has been solved.
Thank you.
Reply #3 - Jan 18th, 2016, 8:08am
For others reading this post, you might want to mention how you fixed it.
For my part, I suspect the problem is that you $fclosed the file in @initial_step, so that it was not open when you tried to $fscanf.
Jacki
Reply #4 - Jan 25th, 2016, 4:30am
Geoffrey_Coram wrote on Jan 18th, 2016, 8:08am:
Hello Geoffrey,
   Thank you very much for your reply. The problem has been solved. The reason for the slow simulation is I define a very big array, and use this array to read in the data file. This array occupies a lot of memory. If I remove this array. The speed is fine.
   By the way, do you know how to read a read starting from the middle part?
   Currently I only know to read in a file starting from the beginning.
   For example:
fileA = $fopen("./A.log","r");
$fscanf(fileA,"%b\n",hold);
   If I want to read in the data from some middle part in the file A.log, can you please suggest how I should do it?
   Thank you.
Reply #5 - Jan 25th, 2016, 7:13am
VAMS LRM 2.4 section 9.2 / table 9-2 says that $fseek is supported in the analog context, so I suppose it's just a question of whether your simulator supports it.
Jacki
Reply #6 - Jan 25th, 2016, 11:35pm
Geoffrey_Coram wrote on Jan 25th, 2016, 7:13am:
Hi Geoffrey,
   Thank you very much. I will try it.
