Apr 29th, 2024, 12:34am
How do I generate the following voltage profile? (Read 1661 times)
Rosh
Jan 19th, 2016, 7:18pm
Hi everyone,
I am trying to generate the following voltage profile.
Picture attached.
The specifications are :
Vhigh: Voltage 1
Tr: Rise time
Vlow: Voltage 2
Time: Time after which Vhigh falls to Vlow
Tf: Fall time
`include "disciplines.vams"
module series_rlc1 (p, n1);
    parameter real r=1,vout_high=5, //VHIGH value
	trise = 100u, //Fall Time
    tfall = 100u, //Rise Time
	vout_low=3, //VLOW Value
	droop_time=3000u;//Time after which VHIGH falls to VLOW
    inout p, n1;
    electrical p, n1;
    analog begin
	V(n1) <+ transition(vout_high,0,trise,tfall);
	if($abstime==droop_time)
	V(n1) <+ transition(vout_low,0,trise,tfall);
However, I get an error saying I cannot include a transition operator inside a conditional statement. So how do I tell the compile to drop the voltage after a time?
Re: How do I generate the following voltage profile?
Reply #1 - Jan 20th, 2016, 8:05am
I think you are missing some basic understanding of how the Verilog-A contribution operator works.  The code you posted would set the voltage on "n1" to vout_high for all time *except* for the timepoint exactly at droop_time.
I think the code below will work better.
    inout p, n1;
    electrical p, n1;
    real vout;
    analog begin
	@(initial_step) begin
		vout = vout_high;
	if($abstime>=droop_time) begin
		vout = vout_low;
	V(n1) <+ transition(vout,0,trise,tfall);
However, I get an error saying I cannot include a transition operator inside a conditional statement. So how do I tell the compile to drop the voltage after a time? [/quote]
