May 1st, 2024, 3:23am
ncelab no connection module found (Read 3557 times)
JayM06
Jan 20th, 2016, 6:14am
Hi guys,
So i'm quiet new to the verilog ams but it has been over 2 weeks that i'm working on it. I read all the posts before coming here, several docs on cadence and some literature.
Anyway i have a problem with the connection between an analog module (resistance) and a digital one (clock generator). Both these modules were taken on this page's tutorial on verilogAMS.
ncelab: *E,CUVNCM (./test_res.vams,12|35): No connection module found:Need an input port of discrete discipline logic, and an output port of continuous discipline electrical, at instance top.clock_gen1.
i already checked the libraries and i do have the connetLib. The automatic insertion isn't working based on the error.
Please help i have no more ideas
Thank you for your replies
AMS_ei
Re: ncelab no connection module found
Reply #1 - May 23rd, 2016, 11:36pm
It is looking for L2E connect module. What is the default discipline that you have set?
AMS_ei
Reply #2 - May 23rd, 2016, 11:38pm
what is the code in line no. 12 of that file?
