May 2nd, 2024, 12:59pm
Output for a pulse is just a DC voltage. Help! (Read 2138 times)
Rosh
Jan 28th, 2016, 7:02pm
Hello everyone,
Here is my code :
`include "disciplines.vams"
module allo(out);
parameter real td = 10n;
parameter real tt = 10n;
parameter real t1 = 0n;
   output out;
   voltage  out;
   real Vout, tend;
analog begin
	@ (initial_step) begin
		 Vout = 0;
		 tend = $abstime + td; //return simulation time + td;
	  @(timer(tend))
		 Vout = 1.8;
		 V(out) <+ transition(Vout,0, td, tt);
I expect to get a pulse with a finite rise and fall time. Instead i get this:
deltasigmaADC
Re: Output for a pulse is just a DC voltage. Help!
Reply #1 - Jan 29th, 2016, 2:58am
Your variable Vout is always assigned to 1.8. So you should be getting a DC at output, which is what you are seeing. Probably you wanted to update the variable to 0 at some point in time as well.
Cheers
Reply #2 - Jan 29th, 2016, 10:55am
Your indentation is confusing; it looks like the V(out) <+ transition is inside the @timer block.
analog begin
	  Vout = 0;
    @(timer(tend)) begin
	  Vout = 1.8;
