Apr 28th, 2024, 10:55pm
Creating two pulses with different rise times using two transition operators (Read 1453 times)
Rosh
Jan 31st, 2016, 10:26pm
Hello all,
I have to generate two pulses, each with different rise times.
This is my code
`include "disciplines.vams"
module vdriver(out);
parameter real td = 10n;
parameter real tt = 10n;
   output out;
   voltage  out;
   real Vout, tend,rst;
analog
begin
	@(timer(0))
	begin
	Vout=0;
	@(timer(20n))
	begin
	Vout=5;
	@(timer(40n))
	begin
	Vout=3;
	@(timer(60n))
	begin
	Vout=5;
	V(out)<+transition(Vout,0,td,tt);  //Rise=Fall=10n
However, I'd like the second the second pulse to have a different rise/fall time.
If I add a second transition operator however, the entire waveform goes haywire. Any recommendation to solve this?
Re: Creating two pulses with different rise times using two transition operators
Reply #1 - Feb 1st, 2016, 10:48am
You are already changing the voltage of each transition. Use the same technique to change the transition time.
In otherwords, make tt a variable that you set when you set Vout.
