Apr 27th, 2024, 4:45pm
Error while compiling a circuit including a verilogA model (Read 2610 times)
dollysi
Mar 03rd, 2016, 7:28am
Hello everyone,
I am designing a circuit which includes latches and a verilogA model of a memristor. After compiling; following error appears in AMS Result browser:
ERROR  256: In file "./latch.cir" line 227:
+   OBJECT "YI30": The sign : is missing after keyword MODEL .
latch is the name of my schematic circuit which includes YI30 (which is my verilogA memristor model).
I am very new at this so I am having a lot of trouble compiling this.
Re: Error while compiling a circuit including a verilogA model
Reply #1 - Mar 3rd, 2016, 11:57am
Without seeing any of your files, we'd be guessing blindly.  At least show us line 227!
dollysi
Reply #2 - Mar 3rd, 2016, 12:03pm
The latch.cir file is automatically generated file. I think no change should be made in that, but I guess the verilogA code (which I am linking) has some problem.
http://webee.technion.ac.il/people/skva/Memristor%20Models/Verilog-A/memristor%2...
This is my verilogA code.
Even if I use this model with other circuit, the same error is being displayed.
(filename.cir )
Reply #3 - Mar 4th, 2016, 7:04am
I opened the Verilog-A file and found this line:
  parameter real model = 0;
It's not on line 227, and MODEL isn't a keyword in Verilog-AMS, but I wonder if the simulator you are using has a problem with it.
The netlist you sent me by PM did not include an instance of the memristor, only a voltage source.  I suppose you specify a value for the parameter 'model' on the instance line.
I would suggest you rename this parameter to "model_type" and see if that solves the problem.
