Jul 24th, 2024, 3:15pm
Does the threshold voltage of MOS transistors vary with fingers? (Read 1328 times)
iVenky
Mar 31st, 2016, 10:26am
I would like to know if the threshold voltage of MOS transistors vary with the number of fingers in these advanced technologies. I mean compared to multipliers, does the threshold vary?
Thanks!
Re: Does the threshold voltage of MOS transistors vary with fingers?
Reply #1 - Mar 31st, 2016, 11:09am
As a guess, probably not. Important that you get your foundry specific data to get a meaningful answer.
davidshw
China
Reply #2 - Mar 31st, 2016, 11:40pm
yes, dut to LOD and WPE stree effect, the vth is different of different fingers, the matching MOS devices (such as current mirror) should have the same fingers in pre-simulation.
raja.cedt
Reply #3 - Apr 1st, 2016, 2:18am
Multipliers are separated by ST kind of isolation, so fingers adjacent to STI will have higher stress during manufacturing. Where as fingers are adjacent to another finger hence no stress. So Vth strongly depends on where they are.
Please refer LOD and STI effects in Google.
Best regards,
Raj.
Reply #4 - Apr 3rd, 2016, 6:58pm
Go get empirical data to validate.
Too many times I have seen things like thins go in a different direction.
Real world data from real world silicon.
RobG
Bozeman, MT
Reply #5 - Apr 11th, 2016, 12:58am
raja.cedt wrote on Apr 1st, 2016, 2:18am:
Best regards,
Raj.
This is true, but I haven't had to lay them out that way to pass LVS. For example, if the device was M=10, NF=2, you could lay it out as M=1, NF=20 and pass LVS. Extracted simulations are real important to model this sort of stuff.
Dummy devices should be used so the surroundings are the same no matter how many fingers you use. If you use them, it won't matter if you use M or NF.
