Oct 10th, 2026, 5:48pm
Deep nwell devices in tsmc65nm (Read 4955 times)
mixed_signal
Apr 02nd, 2016, 9:39pm
Hi, The deepnwell devices in tsmc65 layout cell has the deepnwell rectangle but no nwell surrounding it. Is it OK to just draw nwell rectangle (path) manually around it? It  passes lvs. Is there any other special layer needed to be added for nwell to get fabricated?
Maks
San Jose
Re: Deep nwell devices in tsmc65nm
Reply #1 - Apr 14th, 2017, 4:06pm
To get a solid contact to deep nwell, you need to draw nwell ring around it, along with nplus and OD (diffusion) with contacts filling the whole ring (M1 above, etc.).
Max
