May 3rd, 2024, 2:58am
Issues with a Differentiator in Verilog A (Read 1835 times)
Omnidroid
Apr 05th, 2016, 3:46pm
Hi Folks!
In order to obtain a derivative of an analog signal, if I use an ideal time derivative operator V(out) <+ ddt(V(in), there is a lot of noise observed at the output. I believe this is because this block does not have continuous states and the inability of the solver to take smaller steps causes the output to change rapidly.
Could anyone please suggest me a convenient option to eliminate this issue and yield a clean noiseless signal at the derivative output with adequate accuracy.
Thanks in advance! Smiley
Re: Issues with a Differentiator in Verilog A
Reply #1 - Apr 11th, 2016, 9:29am
Perhaps you could connect a capacitor to the input, and then make the output proportional to the current into the capacitor.  The capacitor should help the simulator choose good timepoints.
