Jul 26th, 2024, 3:30pm
How to reduce the MOSFET OFF capacitance (Read 5256 times)
iVenky
Apr 09th, 2016, 12:29pm
I am trying to design a capacitor bank for VCO. The thing is the MOSFET switches give a considerable OFF cap when they are OFF because of which I am seeing a reducing the capacitor range in the bank. I would like to reduce this OFF capacitance of the MOSFET and I don't want to reduce the size further because this would increase the ON switch resistance. Is there any technique to reduce this capacitance?
Please let me know if you have any questions.
Thanks!
ULPAnalog
Re: How to reduce the MOSFET OFF capacitance
Reply #1 - Apr 9th, 2016, 1:31pm
Does using capacitance neutralization techniques such as negative miller compensation help?
iVenky
Reply #2 - Apr 9th, 2016, 3:24pm
But you need an amplitude for that negative miller capacitance.
When you so many capacitor banks, that would be a good solution, right?
ULPAnalog
Reply #3 - Apr 9th, 2016, 3:49pm
iVenky wrote on Apr 9th, 2016, 3:24pm:
What is this amplitude?
iVenky
Reply #4 - Apr 10th, 2016, 5:59pm
Sorry it was a typo,
I meant "amplifier"
ULPAnalog
Reply #5 - Apr 10th, 2016, 8:03pm
OK. That might be possible. But it is not entirely clear to me on which part of the off state capacitance is causing the problem and henceforth between which nodes would you insert compensation stage. Can you simplify the problem by reducing the switch sizes and counter the increased on state resistance by gate bootstrapping or using a charge pump to boost gate over drive (I consider bootstrapping a variant of charge pump).
DanielLam
Reply #6 - Apr 29th, 2016, 11:39pm
Can you use a higher common-mode voltages on the capacitor lines? You might try that.
raja.cedt
Reply #7 - Apr 30th, 2016, 1:25pm
HI-
What kind of architecture you are using. is it a simple Cap in series with grounded switch or a differential cap connected through floating switch? You can use RC filter based common mode shifting technique (refer the following pap) or floating switch tech with side ground switches (Refre Razavi RF book)
http://ieeexplore.ieee.org/xpl/login.jsp?tp=&arnumber=1025154&url=http%3A%2F%2Fi...
Raj.
BennJoltes
Reply #8 - May 25th, 2016, 11:30am
Hello everyone..i am new here. As per my my knowledge it is not clear to me on which part of the off state capacitance is causing the problem and henceforth between which nodes would you insert compensation stage. Can you simplify the problem by reducing the switch sizes and counter the increased on state resistance by gate bootstrapping or using a charge pump to boost gate over drive.
