raja.cedt
HI- Yes that is called time constant based calculation. Elmore delay is based on dominate time constant, means in the transfer function ignore all s power terms except constant and s-coefficient. Hence this pretty accurate if systems is dominted by single time constant. For a given network if one R and one C domintes this works generally. Please post which circuit is creating problem.
Best Regards, Raj.
