Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Apr 28
th
, 2024, 12:22pm
Home
Help
Search
Login
Register
PM to admin
Design
Mixed-Signal Design
› large driver need ESD
Previous topic
Next topic
large driver need ESD (Read 973 times)
zelda
Apr 14
th
, 2016, 1:52am
Hi
If the Tx drivers which have large width, do they still need ESD protection like gated PMOS & gated NMOS? assuming total tx driver size is more than min ESD requirement like min 300um
IP Logged
raja.cedt
Re: large driver need ESD
Reply #1 -
Apr 15
th
, 2016, 3:54am
You will still need some ESD for +vs Zap, because transistor drain to bulk diode always give only one side protection..
Raj.
IP Logged
zelda
Reply #2 -
Apr 20
th
, 2016, 2:15am
hi Raj,
could you explain more in details?
why should it need more ESD protection?
the driver has met min length and min total width requirement.
IP Logged
raja.cedt
Reply #3 -
Apr 20
th
, 2016, 8:10am
I mean every transistor Drain has it's own diode, so it is self protective up to some extent in one direction, that's why people add big gurad ring so that it is even more effective but this can't add diode in another direction.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
»» Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
