Jul 25th, 2024, 9:23pm
Delay Lines for Calibrating Sampling Clocks (Read 1029 times)
DanielLam
Apr 29th, 2016, 11:33pm
Hi everybody,
I've been doing a literature search on delay lines for sampling clocks, and there seems to be two main contenders.
1) Current-starved inverters
2) Adding caps onto inverter outputs
Which is more preferable for delay lines for sampling clocks? I am not talking about VCOs where current-starved inverters are prevalent.
I am leaning towards the capacitors as I assume they have less jitter from the supply rails. I am just wondering about other peoples' thoughts.
Daniel Lam
