Jul 26th, 2024, 1:20pm
Nulling the parasitic inductance of package (Read 1960 times)
Shanw
USA
May 04th, 2016, 7:34pm
My driver is short to the package, and I found that the parasitic inductance of the package can cause bad signal.
Besides making parallel package to reduce the inductance method, is there any other method I can do? Thanks.
raja.cedt
Re: Nulling the parasitic inductance of package
Reply #1 - May 6th, 2016, 8:34am
Not relay. But be careful on parallel package, that wont make your Inductance half of the original value due to mutual coupling. You can prove on paper that under perfect coupling (K=1) there is no change in the resultant Inductance. Few people try to reduce the loop area by keeping bond very close to the package plane, but this has reliability issues.
I would go with less slew rate, if circuit allows or consider Flip-chip if there are no thermal issues.
Best regards,
Raj.
RobG
Bozeman, MT
Reply #2 - May 16th, 2016, 10:12am
I agree with Raja on two bond wires not make that big of a difference, but it does help. I'm not sure what you mean by "bad signal." If it is ringing then you can add some series R to dampen LC circuit.
